anyone with a 327....please help!
Old May 31, 2002 | 01:51 PM
woody86's Avatar
i have a pre 69 327. i doesn't have accessory holes in the heads. i can't find a passenger mount alternator bracket anywhere.......please help!
Old May 31, 2002 | 06:28 PM
iroc22's Avatar
Do those heads even have hardened valve seats? Why don't you just pick up some newer heads? They will make more power, are easy to find and will solve all your troubles easily.
Old Jun 2, 2002 | 11:42 AM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
woody 86 I agree with iroc22
Use different heads for your 327 and you'll get your accs. holes for your bracket, your older 327 heads are all the same and dont have the bolt holes we need
Old Jun 2, 2002 | 09:36 PM
bradkeith's Avatar
woody, i believe that unless you want o spend big bucks there isn't a pass. side alt bracket. I was running pre-69 heads and used the header/waterpump bracket for my alternator. Are you also running a short water pump? AC?
Old Jun 2, 2002 | 09:47 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I beg to differ.....Not my motor but I used the same bracket with the long water pump off a 70's caprice...
Old Jun 2, 2002 | 09:56 PM
woody86's Avatar
i'm using a long water pump. i'm gonna wind up fabricating something i'm sure. nothings ever easy is it?
Old Jun 2, 2002 | 09:58 PM
Engine: 406
here is mine on the 327..as you can see it bolts to the W/p and the intake...I may have an extra one if you cant find one at the JY...I'll have to look, let me know.
Old Jun 2, 2002 | 11:19 PM
Engine: 406
Bottom bracket also connects to W/P....just a flat pc with 3 holes
The oil you see came from a leaky non used f/p it has since been fixed,
Old Jun 2, 2002 | 11:22 PM
Engine: 406
oops, Hope this helps....
PS..by the way Woody, did you know that 327's are all 2BOLT MAINS stock?...PSS..mines not..
Old Jun 3, 2002 | 04:44 AM
woody86's Avatar
thanks man. i really appreciate all the help. it looks like it would twist under load with the back side of the alternator not being secure, but if you've been running it i'll give it a try. looks like another trip to the junk yard!
Old Jun 3, 2002 | 05:39 AM
Engine: 406
the brackets are very ridgid..I haven't noticed any twisting, I suppose if yo did have a problem with it you could run a strap off the top bracket...some how...Have a great monday
Old Jun 3, 2002 | 08:16 AM
79Z's Avatar
79Z
woody...the back/lower side of the alternator is secured by the long bolt,about 5"-6",running thru the alternator casting into the head.If you think finding alternator mounts is tough,I looked high and low for the passenger side mount that bolts to the thermostat housing as my old 70's(?)Offy intake didn't have the hole for the back of the bracket.Finally found one in a pile of parts in an old van at the junkyard,man was I happy to find it.And yes..all stock 327's were two bolt main,but a 4 bolt 327 is easily put together with a 4 bolt 350 block.
Old Jun 5, 2002 | 07:20 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I have a 307.. what I did was put the LG4 305 heads on the 307 block so I would have the accessory holes. Worked out great.
