TBI-TPI swap
Old Jun 30, 2002 | 06:20 PM
mattRS's Avatar
TBI-TPI swap
how hard would it be to put the harness from a TPI car into an 89 305 TBI?
Old Jul 1, 2002 | 12:14 AM
InTeRcEpToR5.7l's Avatar
i'd like to know also
Old Jul 2, 2002 | 11:38 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
somebody please reply that knows how hard it would be, i am going to do the same to my car and i need to know.
Old Jul 4, 2002 | 01:56 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i'm finishing up my 305 TBI to 350 TPI swap and i'll tell ya it's not easy.but it will be worth it.the hardest part was the fuel pump i spent way to much time in trying to get that ****er out the "right" way.i said **** it and did it the easy way i cut a "access" panel in the body to make it easier to get it in an out.after cuttin gthe access panel i then cut the fuel lines with a small pipe cutter and after i got the pump back in i used compresstion fittings to put it all back together.i'm glad i made a panel because it turns out the new pump that i bought from www.apeusa.com was bad.i got into contact with APEUSA and was told to send it back and he'll ship me out a new one.
now when it comes to the wiring harness i would try and find one that is out of the same year car as yours.or you could go the route i went and have your harness converted.when i bouhgt my motor the harness and ECM came with it,i wanted to go with speed denisty so i needed to have it converted.check out www.chevythunder.com.Leonerd Sparks was very helpful i don't think I could of done it with out him.at least check out his web site there is soooo much info there.
well that's all for now feel free to PM me or e-mail me if you have any questions
Old Jul 12, 2002 | 08:39 PM
mattRS's Avatar
thanks a lot bandit. let me know how it ends up!
Old Jul 13, 2002 | 07:41 AM
91banditt2's Avatar
Engine: 5.7 HSR
i received the fuel pump in the mail yesterday so hopefully she'll be prowling the streets this weekend
i have a Mustang to hunt down :rockon:
Old Aug 21, 2002 | 03:23 AM
mattRS's Avatar
so how did it turn out?
Old Aug 21, 2002 | 06:15 AM
91banditt2's Avatar
Engine: 5.7 HSR
https://www.thirdgen.org/techbb2/sho...hreadid=125771
Old Aug 21, 2002 | 10:43 AM
mattRS's Avatar
damn. sounds like you are having some problems. that would be my captain obvious statement of the day
Old Aug 21, 2002 | 03:18 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
well i am going to start my swap on monday and i hope nothing like that happens to me. i am getting a holly pump for my car so maybe i don't have to worry about all this. i really need my car to drive around and i cant have it parked waiting for parts.
well good luck man let us know what happens in the end.
Old Aug 22, 2002 | 11:13 AM
91banditt2's Avatar
Engine: 5.7 HSR
well i hate to be the one to break it to you but a Holly fuel pump is just a repackaged Walpro pump.open up the nice neat Holly box and you'll find a Walpro pump inside.
Holly(walpro)pump $130ish to $180ish
Walpro pump from www.apeusa.com $103
Old Aug 23, 2002 | 03:33 AM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
hahaha ya damn that was a close one almoust bought that pump well thanks for the info but just to let you know i am going with a bosch fuel pump capable of suporting 550 hp. i think i will like that one much better then the holly.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
