motor swap ??????s
Old Jul 5, 2002 | 04:58 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
motor swap ??????s
i tried asking before but no response.... im swapping into my car a 350 that is out of a late 70s car.... i have heard people say that some motors have 2 peice main seals, when i replace the seal i get the one that is correct for the motor, right?? and also is there any other bolt up issues i will run into?
Old Jul 5, 2002 | 05:22 PM
iroc22's Avatar
Yes it will be 2 piece rear seal. Get that seal. The problem bolting it up is it will require a 2 piece rear seal flexplate/flywheel.
Old Jul 5, 2002 | 09:44 PM
stevver84Z's Avatar
which flywheel do i use the 350 one or the 305 one??
Old Jul 6, 2002 | 09:28 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use a flexplate/flywheel intended for an '82-85 3rd gen. It will have the proper bolt pattern, and will fit within the bellhousing. Since your car is an '84, you should be able to reuse your current piece, assuming it's in good condition.
Old Jul 6, 2002 | 09:49 AM
stevver84Z's Avatar
are they a different tooth pattern?
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
