Swapping to V8, What do I do about the V6 computer?
Old Jul 12, 2002 | 06:10 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
I am currently putting a carbureted 350 in my V6 car. I know the computer will not work with the motor, so what do I do about it. Do I have to get a V8 computer? Bypass it?
Old Jul 12, 2002 | 09:22 PM
I know someones had to deal with this problem! c'mon talk to me!
Old Jul 12, 2002 | 09:48 PM
Guest
Guest
Posts: n/a
Depends... is the new engine computer controlled? If not, ditch the computer and get a lockup switch for the tranny.
Old Jul 12, 2002 | 10:01 PM
gearhead86's Avatar
If Alabama doesn't have an emissions check and inspection or smog test then do what I did with my 86 car axe the computer and the wiring altogether! Mine started life as a v6 multi-port car(WHAT A TURD!!) and is now a 355. I found out that all the wiring that comes out of the firewall on the drivers side is the critical wiring that you need for the car to run,have all lights and all gagues to work. All the wiring on the passenger side that comes up through the fender can be tossed.On my 86 it was all for the sensors, injectors,etc. Youre 83 should be close to an 86.
Old Jul 13, 2002 | 12:02 AM
Don't some of the wiring on the pass side go to the a/c stuff? b/c I wanna keep my air!
Old Jul 13, 2002 | 12:03 AM
Oh, the new engine won't be computer controlled.
Old Jul 13, 2002 | 12:48 AM
Guest
Guest
Posts: n/a
The only wiring to the AC stuff does not go through the firewall to the ecm on your car, its next to the airbox where the heater and stuff is.
Old Jul 13, 2002 | 05:41 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
on the carbed swap..you will go from about 700 wires to 7....the old v-8's were fairly simple...if you got gas, and fire its gonna run. Back to basics here....
F.I. 57 Belair
Aug 23, 2021 01:09 AM
dusterbd
Sep 29, 2015 08:40 AM
Camaroguy2
Sep 22, 2015 08:22 AM
apie2546
Sep 20, 2015 01:03 PM
Keith5
Aug 27, 2015 04:37 PM
