Swap With Or With Out Headers On
Old Jul 30, 2002 | 12:30 PM
ROCKNRODS's Avatar
We are doing the swap this weekend.
Headers are allways a pain so can u put them on before droppin in the engine? long pipes
350 w/700r4 attached and by the way the idiot who rebuilt the old trans welded in the cross member and welded a bolt on the motor mount to keep it from hittin the pan. Motor mount was $13
Some of the boards say its hard to put duals on. Is this because of just ground clearance and emissions. I dont have to worry about emisions but ground clearance can be a problem. Would like 3 inch, friend just had 2.5 put on for 215 on old pontiac grand prix so I know the local shop will do itbut will i have problems?
any sugestions?
Old Jul 30, 2002 | 01:36 PM
ATOMonkey's Avatar
Headers in the car is the way to go, but requires a couple extra hands or more. It's a ground clearance issue. I have 4 in. of ground clearance at my highest point. If you don't mind doing a lot of banging around on the floor pans, it is possible to run the drivers side down by the trans and drive shaft. LOTS of banging.
1984HO
Mar 19, 2021 11:59 AM
AussiePr0nCar
Mar 6, 2020 04:04 PM
InfinityShade
Aug 22, 2015 08:00 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
