Air Conditioning Brackets and Headers
Old Aug 3, 2002 | 09:34 PM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
OK, if I install a new 350 into my IROC, and add headers (Elderbrock in my case) how do you connect the A/C and other accessory brackets that use the forward exhaust manifold bolt? The stock forward bolt has a stud sticking out and the accessory bracket goes on and a nut holds the bracket in place. What have you guys done to support the brackets? Pictures would be a great help!
Old Aug 3, 2002 | 10:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I just made a spacer such that the thickness of the flange plus the spacer was equal to the thickness of the exhaust manifold, and used the stock hardware. I'm pretty stupid actually so I keep things as simple as possible.
Some spacers come in the TES kit (at least they did in mine) but they were too long to use for anything; 30 seconds of hacksawing later, problem solved, perfectly. All my A/C and PS brackets are back on in their stock locations, the A/C blows cold.
Old Aug 4, 2002 | 03:59 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Exactly what I did to mount my P/S without AC and acc holes in my DH heads.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
jackhammer
Aug 15, 2015 10:04 PM
