Has anyone ever ont this? Lt1 heads on Gen 1 block
http://www.lt1intake.com/LT1_retrofit.htm
I would like to do this swap but would like more detailed info on it. Any more info on this swap would be great.
Thanks, Curtis
AIM: Curt82
Thanks, Curtis
AIM: Curt82
Transmission: 4L80E/4L80E
"The end result was an increase of 36 hp over the standard ZZ3 H.O. aluminum heads."
If you can't find 36 hp by reworking ZZ3/ZZ4/Vette aluminum heads for less money than modifying LT1 heads will cost you, then you should go back to driving an Accord.
The work that has to be done is detailed in the article you linked. That is extensive work, and unless you're doing it yourself (have a machine shop in your back yard?), it's going to run some serious coin.
No, I don't know exactly what it would cost to do those modifications. Do you?
1992 Trans Am
Aug 8, 2015 08:16 PM
