does anyone know vette 58cc heads
Old Aug 19, 2002 | 02:13 PM
fastvetteTPI84's Avatar
i have the 113 58cc chamber vette heads on my car does anyone know if i could mill the head down much more ,im using just stock pistions ( flat 2 valve releef ) . without hiting the valves or the pistion .. id like to bring it down to 52cc if possable
thanks
Old Aug 19, 2002 | 02:51 PM
ede's Avatar
ede
you shouldn't have anything to worry about, but you should always dummy it up and check to be sure.
Old Aug 19, 2002 | 03:26 PM
ATOMonkey's Avatar
Or, you could get a dial indicator and measure from the deck to the piston reliefs, and then from the head to the valve at .500 lift or whatever your cam does. Add in .020 or so for the head gasket and your there. Then you can figure how much you can cut off the head before you wack a valve. Be sure to also add in a little extra room for "dynamic valve lift" Extra lift because the spring can't stop the valve fast enough. That might be somewhere around .010 or so. What is this engine for? Your compression is going to be well over 14. Or are these heads going on a 305? Just for my curiosity.
Old Aug 19, 2002 | 03:56 PM
Mark W. Winning's Avatar
I have mine cut to 55cc and I know a bit more is possible. When in doubt, the person doing the milling can mic them.
Mark
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
