How to swap an engine
Old Jun 21, 2003 | 11:22 PM
  #51
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
well, im just about ready to pull it now, i just have to figure out what ill do about the pullies. the ac and aip pump are gone. do u guys have any tips on what to do? i dont want to have to leave that bracket in there just for the tensioner, nor do i really want to buy that idler pully. is there a way to route it? i did search but couldnt find anything
thanks
Old Jun 24, 2003 | 05:28 PM
  #52
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Just one thing to add to the Post about how to remove it step by step. I recently Removed the engine outta mine (LT1 Goin in!) and the easiest way to remove the tranny was to unbolt the 2 bottom, and 2 middle bolts, and the way i got the top ones off because tools didnt reach it was to get like 3 LONG extensions, like 3 feet or so, and go from where the driveshaft connects to the tranny. Sounds wierd, but if you are lookin from back there, you can see the bolt fine. It came of EASY. I was in Auto Shop and had it on a lift 6 feet up, mabey that made it easier, but it doesnt look too hard on the ground either, lol
All from the bottom....
xkingcodex
Feb 12, 2020 07:43 PM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
