305 to 350
Old Aug 25, 2002 | 12:12 AM
brihoop's Avatar
305 to 350
what is needed to swap from a 305 to 350?? do you have to get all new wiring and computer, or do you just use the old stuff? is there anything else??
Old Aug 25, 2002 | 07:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Depends upon what you have now.
Carb - no big issues, just tuning, mainly. If LG4, air cleaner and exhaust have to go (but that's the case if you keep it an LG4, anyway).
TPI - no big issues, if cam is kept reasonable, adjustable fuel pressure regulator helpful to aid tuning. Porting of plenum and base, and larger/shorter runners typically help. In some cases, larger injectors helpful. Custom PROM will help optimize as performance improvements are undertaken.
TBI - seems to be the most sensitive. But, many have done it, TBI forum is the right place to ask.
In all cases, exhaust upgrade is in order. Headers a good idea, and good-flowing y-pipe, cat, cat-back.
Old Aug 26, 2002 | 06:23 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
This may help u.
https://www.thirdgen.org/techbb2/sho...hreadid=127674
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
