305 TBI to 305 TPI Swap
Old Aug 29, 2002 | 12:44 PM
RedRS90's Avatar
Hey everyone, I already have the TPI setup, I would just like to konw what I will need besides the engine wiring harness to convert over to a TPI, the TPI is an 85, the Engine Block is a 90. Do I need a different Cam to expect the same amount of horsepower as the IROC's? or is there a Better cam that I could use to get more HP than the 305 IROC'S?
Old Sep 14, 2002 | 11:25 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
you do know that you will have to modify the four inner bolt holes on the intake base right?
Old Sep 15, 2002 | 12:21 AM
gettaway305's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I hope you have a new ecm and all the sensors for the harness too...
Also I believe you need the TPI fuel pump
Old Sep 15, 2002 | 12:55 PM
FLYNLOW92rs's Avatar
The tech article on the main page has a list of all the parts you need for the change.......
Old Sep 17, 2002 | 11:08 PM
RedRS90's Avatar
well I, guess I do now, is that gonna be hard? I mean I was told that it should just swap over easily, it may just be easier to rebuild the 350 and drop it in
Old Sep 20, 2002 | 03:47 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Some people say the swap is worth it, others say it isn't. I don't know anyone personally that has done the swap so I can't say. My opinion would be to stick the TPI on a 350. Is it a stock tpi, or has it been modded to breath? If you decide to put it on your 305 L03:
TPI is stock and you plan on leaving it that way: You can use the stock TBI cam. The TBI cam is weak hp wise and dies out around 4,500-5,000rpm. A stock TPI can only breath to about 4,500rpm, so it should match up, and you should feel more mid range torque.
TPI is modded to breath or will be in the near future: Swap that old peanut cam out for a real cam!
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
