motor rebuild class?
Old Aug 29, 2002 | 06:12 PM
Matt's Avatar
My minor in college is auto service repair. In my engines class we need a project. I have an 84 trans am with a 305. What would be the price of parts to rebuild the motor from the bottom up. I know some machineing needs to be done so dont include that. Also if you could include a parts list. I know the main things but sure I would miss something small. Thanks a lot for the help.
Matt
Old Aug 30, 2002 | 11:39 AM
Matt's Avatar
HOW ABOUT A 350
what would be the cost of a 350 rebuild not including the price of teh block it self or machine process?
Old Aug 30, 2002 | 01:43 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
There's a kit from Powerhouse that is really cheap. It's designed for a basic overhaul, not performance. It comes with cast pistons, rings, freeze plugs, bearings, etc., and a stock profile cam.
IIRC, the 350 kit is $158 and the 305 kit is $178. That's pretty gosh darn cheap if ya ask me.
AJ
Here....
MASTER ENGINE KITS (for any engine) New Oil Pump • Rod Bearings • Main Bearings • Pistons • Rings • Cam Bearings • Cam (ex) • Lifters • 3 piece Timing Set • Brass Plug Kit • Gasket Set • (most to '84 carb) Buick 231 $ 199 Chev 173 $219 Chevy 305 $179 Chevy 350 $ 153 Chevy 454 $309 Dodge 318 $ 254 Dodge 360 $ 259 Ford 289/302 (to 81) $179 Ford 351w $229 Ford 460 $309 Olds 350 $325
www.enginekits.com
Old Aug 30, 2002 | 01:49 PM
AJ_92RS's Avatar
One more thing. IIRC, there's a ~$50 core deposit on the cam. And you can upgrade the cam to a higher profile if you like, albeit more $$. That way if you're rebuilding the 305 in your car, you can step up the performance a little at the same time.
AJ
italiano67
Dec 11, 2016 09:21 AM
fbirdroller
Sep 2, 2015 10:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
hokis
Aug 9, 2015 03:57 PM
