Tpis Mini Ram Ii
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
Tpis Mini Ram Ii
I am almost done my new 383 install, and as I am hooking up the Tranny cable (TV) and the throttle cable and cruise control cable it seems that they are too far back because I have to stretch them to get them on the tb... so it make it like open throttle already, anyone had this problem before? if so what did you do, I was thinkin of drillin the bracket and moving it forward a bit, let me know! thanks!
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
Do you have the bracket that bolts to the top of the fuel rail? It is used for the throttle cable...As for the cruise control, you can adjust it at the back of the driverside headlight. I have no idea about the TV cable, no problems here.
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
You should be able to hook up your TV cable then go and floor the gas pedal, that should adjust the TV cable perfect. You'll hear it click into position. Just don't floor it TOO hard, if you feel serious resistance stop and check for something odd around the TB area.
thanks for that help, im gonna check for that bracket! as for the tV cable I know how to set it it just seemed a little tighter than before and I dont want to run it low on fluid pressure !tha twould suck!!! thanks again =)
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 11, 2015 06:55 PM
