bad regulator or bad guage??
Old Sep 9, 2002 | 09:53 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ok guys my car stalls when i turn hard or hit the brakes hard when in nuetral and on the edelbrock website it said high fuel pressure can cause this to happen. now i think this is my pro cause i converted from TBI to CARB and used a mallory 3-port regulator and i have a sumit guage hooked up to it and when i adjust my pressure to lik 5-6 the next day it will be 2 or 12 or sumtin way wrong so i re adjust it. i am thinkin my guage is bad so i am gonna replace it tomorrrow and see if that works. now if the regulator is bad wut coudl go bad in it? and could i fixit cause i don;t think i can return it anymore. thanks guys
Old Sep 10, 2002 | 08:55 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Had the same problem with my pressure reading inconsistant from day to day..more like hour to hour.Turns out the gauge was bad..try a new gauge first.I went with an Autometer in car gauge with isolator.6 psi all the time no matter what
Old Sep 10, 2002 | 09:35 PM
Car: 89 Formula
Engine: Carbed 5.7
by any chance did u have a summit guage?? i was thinkin about the in car guage but its to much money cause of the isolator, then i was thinkin get the outside one and put it in a cup on my hood but i figured it might not work right or sumtin. so i am goin with the kind that just goes in your fuel line.
Old Sep 11, 2002 | 12:29 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Wasn't a Summit..it was a Russel guage.I am pretty sure they are made by the same company.The in car gauge is fairly expensive..but I can keep my eye on it at all times..makes me feel better to be able to monitor what is happening under the hood while driving.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Fronzizzle
Sep 8, 2015 12:10 PM
89fast5oh
Sep 8, 2015 09:55 AM
lakeffect2
Sep 7, 2015 03:52 PM
andy74
Sep 3, 2015 08:41 AM
