700r4 bolt to a 350 crate
Old Sep 10, 2002 | 01:06 PM
camaroman305's Avatar
will the 700r4 bolt onto the 330/350 HO Deluxe crate engine without any problems? I would like to keep the overdrive, but just in case i have a th-400 on standby.
Old Sep 10, 2002 | 01:21 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You will need a one piece rear main seal flexplate, if you don't already have one, other than that it will bolt up.
Old Sep 10, 2002 | 01:25 PM
ede's Avatar
ede
if it's a v8 700r4 one from a v6 won't work
Old Sep 13, 2002 | 10:47 AM
will it hold up to the power?
Old Sep 13, 2002 | 08:45 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
What are those crate motors rated at, 330hp? It will hold up for a while if you just slap it on there! I would recommend getting it worked on though. I am putting my 700 up to my new fastburn crate motor, but it is getting "rebuilt". I would like to get a th400, not now though, running low on money and i would want to do it right the first time! good luck with the project!
Old Jun 20, 2023 | 04:06 AM
hondabones's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8L V6 MPI
Transmission: 700-R4 Automatic
Re: 700r4 bolt to a 350 crate
Expand on this? There's no answer in this thread... This is partially right.
bradpower
Mar 27, 2011 09:42 PM
no1lkme
May 6, 2005 03:50 PM
Fastcam
May 6, 2003 05:53 PM
fb305svs
Dec 14, 2000 11:53 PM
