SBC to BBC tranny bolt patterns?
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
SAME-sometimes it depends on what tranny as you get the older ones with muti holes for multi engines
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
V8 Chevrolet bellhousing bolt patterns are the same. Buick, Old, Pontic, Caddy (BOP) use a different bolt pattern. As mentioned above, some of the older trannies when BOP made their own engines, may have a dual bolt pattern to fit on BOP and Chev.
Car: 4
Engine: 6
Transmission: 5
What Stephen said...
They are the same.
Motor mounts are the same (although there are a few varieties to choose from to obtain optimum fit).
Flywheels and flex plates are the same in the 86-back versions(except for balance issues, which are easily overcome - but the bolt patterns are the same).
Distributors, starters, and flat tappet lifters are the same.
Everything else is different.
They are the same.
