ram jet 350 options
ram jet 350 options
I was planning on buying the 502 ram jet when I get back home, but I spent more cash than I could. I can still afford to buy the 350 ram jet though. I was just wondering, is it possible to put a supercharger on there with its own cpu?
Car: 86 Iroc-Z28
Engine: FB385
Give me some money so that i can get one from ATI! J/K Call up a place like Scoggin-Dickey and ask around. Not too many people have dealt with that motor on this board. Right now i do not know of any thirdgen sportin that motor. It would be bad *** though, even without the s/c. All it says in the description is that it comes with a pre-programmed ECM controller. good luck
Car: 1989 camaro RS
Engine: RAMJET 350
Transmission: RAPTOR 700-R4
i have the ramjet 350 in my 89 rs. the ecm that comes with the engine is not easily programed. i think its very possible to add a supercharger its just more air. the motor itself runs rich. so the extra air should balance out the fuel. and if u have emissions testin good luck cuz its almost impossible to get that to be emissions legal
Car: 1989 camaro RS
Engine: RAMJET 350
86iroc. no i havent had time to got to the track and im not finished so i wont be doing any dyno runs until im done. yea this motor is great i have no problems breaking the tires loose. even when im cruising around and i punch it i can break the tires loose.
thanx
BRIAN
thanx
BRIAN
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Run the ramjet intake, rails, etc with a speed density harness and computer or DFI. Nobody programs MEFI computers, but everyone loves GM 7730.
Car: 1989 camaro RS
Engine: RAMJET 350
dmair5 0 i originally had the 2.8 mpfi v6 the install was pretty straight foward. needed to use iroc mounts and needed a new tranny, and accessory brackets from a v8. i reused my rear end drive shaft and even my suspension. the only problems i had was the oil pan that came with it didnt allow the ypipe to clear so the engine had to come out and an went an iroc pan. also i had to use painless wirings tranny lockup kit. because the ecm does not have an output for it
jmatlock not true arizona speed and marine programs the mefi ecms
Car: 1991 Formula
Car: 1991 Formula
We've also talked to some Mercruiser engineers about giving us a hand. That's about all you're gonna find who can mess with these computers becides GM. They're locked by a password.
Car: 1989 camaro RS
Engine: RAMJET 350
yeah know all bout that its kind of stupid how gm put a ecm thats tough to program and only certain people can play with them. they should of set it up with an easier setup. but i cant complain i love how my car performs the way it is. just have to find the right inspection station if u know what i mean
Car: 1989 Firebird Formula
Engine: 305TBI
Are you running just the motor as is, or did you opt to buy, I think its the O2 sensor that id doesnt come with. I could be wrong. I know there is a sensor you can by, its like $450 for the sensor and some sorta computer, that will make it achevie beter fuel mileage. Any idea what im talking about. I researched this a while back. Wanted to just drop a replacement in, found the engine for $3200, but then I needed a tq converter lock up kit, and then a needed that expensive sensor, so i just went a different route.
Car: 1989 camaro RS
Engine: RAMJET 350
yup that sensor is the o2 sensor kit. it allows oart throttle fuel adjusrtment. and you would of had to send in ur ecm to be programed to use that sensor. im just running the motor the way it came out the crate. it runs fine to me. just cant pass inspection. but i took care of that with a 50 spot to the inspector
9192camaro
16
Feb 3, 2019 12:21 AM
Eric-86sc
Aug 24, 2015 09:01 PM
L98GTA87
Aug 11, 2015 06:55 PM
350, c4, charging, density, iinstalltall, jet, motor, options, ram, ramjet, speed, super, supercharger, superchargers, trannmission
awesome
