little help...
Old Oct 13, 2002 | 10:56 PM
flippinTHEbird's Avatar
little help...
Trying to pull a 305 out of an 88 firebird. I have everything disconnected. I supproted the tranny. Took the 3 bolts from flywheel to the torque converter on the automatic tranny. Then i removed the bellhousing bolts and tried to hoist the engine and remove it. It won't budge. Is there just two bellhousing bolts on each side or is there more? If so where are they and how can I get to them? Any help will be great. Thank you.
Old Oct 14, 2002 | 12:01 AM
87RS402's Avatar
There are 6 (six) bellhousing bolts.
2 on the bottom, 2 straight up from those, and two more right under/behind the heads
Old Oct 14, 2002 | 12:45 AM
Thanks alot. Any advice on how to get to those?
Old Oct 14, 2002 | 02:43 AM
Joshua Leslie's Avatar
the 4 lower bolts can be taken out from underneath.
the top 2 are the worst, you can either clinb into the engine bay, and use a9/16th open wrench(this is what I did) or you can lower the tranny and tilt it, and put a couple long extensions on a ratchet, and get them from underneath.
I would say its easier to get them from the top, you cant get to long of a wrench down there, but if your persistent, and reasonably strong, and the bolts arent super tight, it shouldnt be to much of a problem.
Old Oct 15, 2002 | 12:57 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
I used a ratcheting 9/16th in box wrench perched on top of the motor. just be patient they r long bolts. putting them back in is deven more fun.
Old Oct 15, 2002 | 01:08 PM
Got them out. Had to remove the wiring harness a little sonner than planned. Time to go sell this beast. Thanks alot for the help.
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
Kj Rockz
Jan 6, 2002 06:00 AM
Locry
Apr 29, 2001 12:09 PM
98_1LE
Mar 1, 2001 12:44 AM
