350 swaped and temp and oil guage probs
Old Oct 15, 2002 | 12:38 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
ok got my 350 in and runnin good finally 2 things though.
1) coolent temp seems to be reading twice the temp that it is supposed to be.
2) oil pressure is pinned and doesnt move.
Are the sensorsat fault in the 350?? they worked fine in the 305 but I am using the 350 ones which is a 77 block thnks
Old Oct 15, 2002 | 08:24 PM
SHAGME's Avatar
Car: 1988 IROC-Z
ok not just gauge foir the temp wow is it hot I will put a new thermostat in tomorro but the gauge is still messed up thnks
Old Oct 15, 2002 | 08:38 PM
HybridZ28's Avatar
you are using the '77 350 sensors for the gauges ??
If so change em out to the ones from the 305 and you problems should be solved.
Old Oct 15, 2002 | 08:44 PM
SHAGME's Avatar
Car: 1988 IROC-Z
ok thnks thats what I thought. but I wanted to make sure b4 I di the work. big north easter comin so Ill do it this weekend. I have to get up at 5AM. thnks
Eric-86sc
Aug 24, 2015 09:01 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
