77-87 Truck Engine Specs Chart.
Old Oct 16, 2002 | 09:43 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
Since every one keeps asking the specs on truck motors here r the orig specs for all of u.
http://www.chuckschevytruckpages.com/73-87specs.html
oops
Old Oct 16, 2002 | 10:12 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
you have those spec charts?
Old Oct 17, 2002 | 06:50 AM
SHAGME's Avatar
Car: 1988 IROC-Z
srry thought someone might care
Old Oct 18, 2002 | 09:36 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I think it's cool, although I already have it bookmarked.
I've got an '83 C10 Scottsdale. 2wd, reg cab, 8 ft. bed.
It's the LE9 305cid, 160HP and 235lb/ft of torque, M20 Muncie 4 spd.
The gear ratios are
1st - 6.55
2nd - 3.58
3rd - 1.70
4th - 1.00
And you guys thought that the TH700-R4 has a deep 1st gear ratio. :hail:
The worst part is the stock rear gear was a 3.08, and someone switched it to a 3.42 My top speed in 1st gear is ~15, and my speedo reads about 5 mph too fast since the speedo gear was never changed. I guess I should do that.
AJ
jhawkeye
May 25, 2022 06:33 PM
junkcltr
Aug 2, 2019 11:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
