Stupid SB 400 Question??
Old Oct 27, 2002 | 12:27 AM
Keith27's Avatar
Does a SB 400 have the right hole's for my sensors, like the knock sensor?
Thought I heard somewhere that all the small blocks had them, but Im not sure.
I know where 2 are at now that need to be rebuilt and was thinking it might be a good swap.
Old Oct 27, 2002 | 12:37 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
yes it will have the correct hole for the knock sensor, its just a hole in the block that goes into the coolant passage. there should be a hole on both sides. normally you dont need them, on a non comp controlled engine, they normally have plugs in them.
as far as any other sensors, they will go in the heads/intake etc and the block wont have any bearing on it. hope this helps.
i have a 400 in my garage that needs built, but built the 350 cause it was cheaper.
Old Oct 27, 2002 | 07:47 PM
Keith27's Avatar
Thanks..........
Cleotiz
Jan 6, 2018 08:56 PM
camaro71633
Sep 1, 2015 10:24 AM
downsouthboy
Aug 29, 2015 11:29 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
