Ok, I'm open to suggestions now. . .
Old Oct 29, 2002 | 10:24 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I've been considering the build up of the engine for my project car and I'm not sure that I'll be able to achieve my goals. I originally wanted (still do) a 427 small block that is naturally aspirated. It would be an aftermarket block, either the Rocket Block or a Dart block with a 4.125" bore and a 4.000" stroke, very high flowing heads, EFI/DFI, and a custom ground cam to make power between 2000-7000 RPM with a smooth idle. My intentions were for this engine to make at least 550 HP and 500 lb ft of torque at the wheels. Now I know I've left a few variables out of the equations such as the 1 7/8" headers with a custom exhaust, moser 12 bolt, T56, Jesel shaft mounted rockers, not to mention a ton of other goodies, but I'm still not sure if the engine would possess the power marks I have set.
Primary function of the car will be a weekend toy, maybe occassional autox driving for fun and it will very rarely see the dragstrip.
I'm also now considering a 427 LS6 to try and make that kind of power which I think would possibly be attainable.
So I'm just looking for some input of more experience engine gurus. Thanks.
(This is just to certify that I'm not crazy and I am fully aware of the cost and work this car will take to be completed. )
Old Oct 29, 2002 | 08:25 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
My first suggestion would be to put it in something else beside a 3rd gen. Honestly, don't waste such a combo on a car worth so little. That was part of the mistakes I made, too.
Old Oct 30, 2002 | 09:42 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
For some reason I was expecting an answer like that, lol. I actually had considered getting an 80 or 81 Vette to use as the project but something just told me to stick with the firebird. I'd eventually like to get an 82 Vette as daily driver and have the firebird as my weekend toy and that's the plans I'm sticking with. But I do thank you for your input.
How's the car coming along BTW? I haven't seen anything about it in a while.
Old Oct 31, 2002 | 03:18 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
OK.... Maybe I'm still living in the dark ages, but isn't a LS6 a 454? Or is that what they call a hoped up LS1 like in the ZO6?
AJ
Old Oct 31, 2002 | 08:26 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
AJ, where ya been man? lol. The ZO6 engine is called the LS6 now. But you're right. It's basically gen III LS1 with a different intake, heads, and cam I believe.
Old Oct 31, 2002 | 11:57 PM
AJ_92RS's Avatar
Under a rock..... ya got a problem with that?
Better than calling it an LS5 I guess, right?
AJ
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TBRays98
Sep 6, 2015 05:05 PM
luvofjah
Sep 3, 2015 07:08 PM
