396.... Problem?
Old Nov 5, 2002 | 02:13 AM
WS6_355_TPI's Avatar
396.... Problem?
Anyone here able to tell me if I can fit a 402 in my 86 t/a pretty easily? Am I gunna have to tear out the heater box or anything like that? I already ripped out the air cond. Now I just need to check into if the swap will work. If I go with this, are headers gunna be difficult?
~Cory
Old Nov 5, 2002 | 06:39 AM
ede's Avatar
ede
what do you call pretty easy? wiper motor might be a problem. heater box should be ok.
Old Nov 5, 2002 | 11:56 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
BBC swap info is on my page at www.koolmeister.com
Miles
Old Nov 5, 2002 | 03:26 PM
Pretty easy = LITTLE bit more hassle than dropping in a 350.
How bad is it gunna be for the headers?
Is the initial engine being dropped in gunna be a hair pulling experience? Do I need to remove the front end while installing it?
It is a carbed 86, 350, 5-spd (girlfriends car)
I have a 396 worked up sittin to go in, and switching it with my 700-r4. I just hope that tranny holds up. I have a shift kit and higher stall torque converter.
Old Nov 5, 2002 | 08:44 PM
87RS402's Avatar
It'll fit in the engine compartment but it is tight with headers. I'm going with a short water pump and cowl hood in mine. I had a delay due to other projects but all I have left to do is finish the engine and in it goes with a T-56.
Old Nov 5, 2002 | 11:23 PM
I need a t-56 for my car.... Im stickin 700-r4 in my g/f's
t-56 = too much for me right now
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
