Will the GM Performance 454 fit?
Gen VI
Horsepower: 425 hp @ 5250 rpm
Torque: 500 ft/lbs @ 3,250
Compression Ratio: 8.75 to 1
Block: Gen VI Cast Iron 4-Bolt Main
Crankshaft: Forged 1053 Steel, 4.000" Stroke
Heads, Chamber Size: Rectangular Port Cast Iron, 118cc
Valves (I/E): 2.190"/1.880"
Camshaft, Lift (I/E): Hydraulic Roller, 0.510"/0.540"
Dur. @ 0.050" (I/E): 211/230 degrees
Intake : Tunnel Ram Jet
My question is will the GM 454 fit the chasis of my IROC, the GM site says the oil pan will not clear, i have a friend with a 502 in his, anyone with a 454?
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Well they're the same size externally. Just use the same oil pan that your friend used and it'll fit.
Where there's a will, there's relatives fighting....... OOOPS!!! :sillylol: Wrong cliche...
Where there's a will there's a way.
AJ
AJ
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The early pans won't work. You need one for an engine with the one piece rear main.
You could get a pan from a 91-93 454SS truck. It's a GenV engine but is also a one piece rear main.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
