430 HP in a 3rd Gen...HELP!!
Old Nov 6, 2002 | 07:22 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Ok heres the deal, I am pretty much sure I am getting a 430 HP Chevy 350 w/ dart racing heads, high rise, 9:73:1 compression off of ebay. It will still run on pump gas.... My car already has a built t-350 that will bark all the gears with the 305. My questions are as follows...One-What would your guess be that my 82 Z28 would run time wise with this setup. And Two- What all would I need to add to make this streetable and not breaking anything. Any help would be appreciated. Thanks!:lala:
Old Nov 6, 2002 | 10:31 PM
SMOKY21's Avatar
Car: 85 s-10 soon
Engine: just a small block
Transmission: th350
ford-9-inch-or-a-12-bolt
Old Nov 7, 2002 | 02:56 AM
Joshua Leslie's Avatar
subframe connectors
posi
aluminum radiator
Old Nov 7, 2002 | 06:39 AM
ede's Avatar
ede
pull 4 of the plug wires and you shouldn't have any breakage problems
Old Nov 7, 2002 | 07:25 AM
Momar's Avatar
You could just send it to me, and I will see that it doesnt break "your" car.
Ben
Old Nov 7, 2002 | 10:30 AM
SMOKY21's Avatar
Car: 85 s-10 soon
Transmission: th350
That works too.
Old Nov 7, 2002 | 04:12 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
Go with a 9 bolt(3.45)(3.27) until you can get a 12 bolt. If the converter is small you may wanna go up. I'm assuming with that much hp the tq peak(being carbed) is gonna be quite higher than stock so a 2800 stall may help it more than any other mod...
Old Nov 8, 2002 | 10:21 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
If the car weighs around 3500 with you in it, it should do around 12.8's. I would suggest getting some suspension upgrades. shocks, springs, control arms, polyurthane bushings.
Old Nov 9, 2002 | 12:19 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I think 12.80s is an under estimation pending he hooks up decently.
Old Nov 11, 2002 | 10:43 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Don't worry if it's one of those compnaies off ebay it won't make 430 on a real dyno so I wouldn't worry about it.
Old Nov 12, 2002 | 11:45 AM
bob8748's Avatar
Mine desktops at a little over 500hp. Making "plenty" of mods on her though!
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
Dragonsys
Sep 25, 2015 03:51 PM
