need help with 305 to 383 swap
Old Nov 15, 2002 | 12:01 AM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i'm about to drop in a 383 in my 92 z28 and i have a few questions. i already bought all new intake and 24# injectors and i'm going to get slp headers and a custom chip, what else do i need that i can't use from my 305? and where can i get a custom chip that won't cost me as much as headers? thanks
Old Nov 16, 2002 | 01:22 AM
92TPIZ28's Avatar
Engine: 355
isnt there anyone that can help me?
Old Nov 16, 2002 | 01:29 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You gotta get a new knock sensor and I think an O2 sensor. <---- Not sure on the O2 though.
AJ
Old Nov 16, 2002 | 10:37 AM
Guest
Guest
Posts: n/a
Dont need the o2 sensor, same same.
As for the chip, go order one from a dealer for a 350. It'll be a good starting point. Beyond that, you really should burn your own chips. If you really dont want to go that route, I'd suggest contacting fastchips.
Old Nov 16, 2002 | 08:54 PM
Amrish's Avatar
92TPIZ28...
I am in plans for the EXACT same swap... I want to take out the 305 from my 92z (might be a swapped 350.. LOOOONG story) but i want to replace the 305 with a miniram'd 383 and i am just wondering if you are gonna show your progress or something of that sort... I am just learning how to do engine work and it would be a great deal of help if you could let me know what things you needed new and what you kept from the 305 to how well the swap went
No big deal if your not keep records or such, but it would be awesome if you could get some pictures of your progress. You can contact me by email if you want at ampatel1@vt.edu
Thanks again, i am def gonna keep this post if it goes anywhere
Old Nov 16, 2002 | 09:29 PM
demonchild's Avatar
what do you ppl know about the smaog regulations on the engine? can you put a bigger engine in the car than what came off of the production line?
Old Nov 16, 2002 | 11:25 PM
Guest
Guest
Posts: n/a
A 383 is technically not legal no matter where you go, its a non-existant engine. However, what tech is going to verify the stroke? Externally it looks like a 350, except maybe the balancer and flexplate, depending on the crank you choose to use. Its pretty easy to get away with.
Old Nov 17, 2002 | 12:02 PM
Amrish's Avatar
I dont know about most people here but i would guess a good amount of everyone on these boards knows someone how can get them through inspection....
I went to a place asking about buying headers, and the guy tells me "get headers without air, i'll pass you on inspection" i was like ok... I live in NY and we do have some hefty regulations
Orr89RocZ
Apr 25, 2016 08:28 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
