my first swap
Old Dec 1, 2002 | 05:34 PM
camaro_z28_87's Avatar
my first swap
I have an '87 z28 automatic with a quadrajet. Plan to swap 305 for a 350 with aftermarket carb. What will this do to the transmission and other electronics. Thanks
Old Dec 1, 2002 | 09:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
Question: Why do you want to go with an aftermarket carb? If this is a daily driver, what you've got can't be beat. An aftermarket carb certainly isn't going to give you more power than the q-jet is capable of, or better driveability or gas mileage. Don't forget you'll also need a non-CC distributor with a non-CC carb - more $'s for zero improvement.
Upgrade your exhaust (headers, high-flow y-pipe, cat & cat-back), upgrade your air cleaner (dual snorkel), upgrade your ignition (coil, module) - That's all you really need to do for the 305-350 swap.
Oh, those things are a good idea for a 305. The 350 just makes it more important to do them. The carb and distributor will be fine, though.
Old Dec 1, 2002 | 10:44 PM
MdFormula350's Avatar
well the tranny should be fine, the 700r4 can handle the power of a 350 well..
hows the tranny shift now, if it slips now you might want to rebuilt it..
Old Dec 2, 2002 | 05:12 AM
Thanks Guys
Old Dec 2, 2002 | 11:49 AM
i beat on my automatic 700r4 in my car and its still going strong!!
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
