knowledgable people plz read
Old Dec 8, 2002 | 07:53 AM
chefdan1's Avatar
allright everything is ordered and on it's way to gm to be installed in my 85z w/ a 305. here is the list of parts.
-gm 350 deluxe/ 330 horsepower motor(brand spankin new )
-"raptor 700r4 transmission w/2300 stall)
-slp 1 3/4" headers w/ y-pipe into a catback(w/ no cat) into a flowmaster 60 series muffler
-gm posi rear with 3:42 gears.
well, what kind of numbers can i expect?? horsepower?? quarter times?? i am running a taller tire in the back with weld draglite prostar rims. any feedback would be great!! car should be done in about 2 weeeks!!
Old Dec 8, 2002 | 11:07 AM
chefdan1's Avatar
anyone??? plz??
Old Dec 8, 2002 | 12:39 PM
kevinc's Avatar
Car: 1982 Z28
There some info missing here...intake and carb, TBI, TPI setup? Cam specs?
Old Dec 8, 2002 | 06:35 PM
chefdan1's Avatar
Horsepower: 330 @ 5,500 RPM
Torque: 380 Ft.Lbs. @ 3,800 RPM
Redline: 5,500 RPM
Compression Ratio: 9.1:1
Block: Cast Iron 4-Bolt Main, One-Piece Rear Main Seal
Crank: Nodular Cast Iron
Rods: PM Steel
Pistons: Cast Aluminum
Cam: Lift: .435"
Intake/.460" Exhaust Duration @ .050: 212° Intake/222° Exhaust
Heads: Cast Iron Vortec, 65cc Combustion Chambers
Intake Valves: 1.94"
Exhaust Valves: 1.50"
Rocker Arms: 1.5:1 Ratio
Old Dec 8, 2002 | 06:45 PM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Well
To much to say but if I was guessing not knowing your skill I would say low 14's to high 13's.
Old Dec 8, 2002 | 07:22 PM
chefdan1's Avatar
i originally had a 305 with just exhaust no headers. i will notice quite a bit of difference right?? i know there is a guy on this site called z28boy who has the same setup and he said it was a night and day difference
Old Dec 11, 2002 | 01:55 PM
Pontiacman's Avatar
You should pick up a second or so in the quarter. 13 or 14's. The 305 was probably a 15. I know a guy that had that engine in a 81 2wd pickup. He was doing 95 mph. He put it in his 80 bird and hits about 100 mph. He has a 2.73 rear with a TH350. You'll probably be in overdrive when you are done the quarter mile.
Old Dec 11, 2002 | 03:09 PM
Dirty Rob's Avatar
Keep us up on how the 330 HO works out for ya, considering that swap myself.
Old Dec 11, 2002 | 06:49 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
You really think he'll be in overdrive by the end of the quarter?? My 81 Z28 has 3:73 posi with a TH-350 and a motor with ~350hp and it isn't topped out by the end of the quarter. I can top it out in third gear too. Guessing it to be about 130mph at 6000rpm. It does have a stock converter, however.
Old Dec 11, 2002 | 06:57 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Not to mention, it probably wouldn't shift to overdrive if you were running a quarter mile. That is unless the Raptor 700R4 is modified to fix this.
Old Dec 11, 2002 | 08:27 PM
chefdan1's Avatar
i will keep all of you up on the swap i believe it will take about another week and a half to two weeks. the guy who is doing the work told me it will run like a brand new car when he's done with it im negoitiating on whether to put a new aluminum driveshaft and a new radiator in it to keep it cool. im going to school in miami next year so i want her to stay cool (she's my baby!!) hell, she's hotter than my girlfriend j/k
any ways would i need a new cooling fan to if i decide to do this?? if so which one?? single or dual?? what model?? anyways thanks guys
AussiePr0nCar
Mar 6, 2020 04:04 PM
diana227vegas
Jul 8, 2016 12:27 AM
WIzmo
Aug 30, 2015 02:30 PM
Thornburg
Aug 30, 2015 08:05 AM
inferno15
Aug 29, 2015 01:48 AM
