Need help With DD2000
Old Dec 27, 2002 | 08:49 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I have files for AFR 195 heads and need step bt step direction on how I load the flow nubers into Desktop Dyno 2000. here are the numbers that i need help with.
3.08
ArflwRsrch195,74cc
1 28.000000
1 0.200000
1 0.300000
1 0.400000
1 0.500000
1 0.550000
1 0.600000
1 132.000000
1 198.000000
1 240.000000
1 260.000000
1 262.000000
1 262.000000
1 1.600000
1 28.000000
1 0.200000
1 0.300000
1 0.400000
1 0.500000
1 0.550000
1 0.600000
1 108.000000
1 156.000000
1 178.000000
1 190.000000
1 192.000000
1 194.000000
Need to know how I input this data into DD2000.
Thanks: Dave
Old Dec 27, 2002 | 10:03 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: Need help With DD2000
3.08<--- I don't know what that's for
ArflwRsrch<--- Brand
195<--- Size of intake runner in "cc"s
74cc<---Size of combustion chamber in "cc"s
06<--- I have no idea
1 2.020000<-- The size of the intake valve in inches.
1 28.000000 <--- The method of vacuum was used for measuring (28"/Hg)
1 0.200000\
1 0.300000 |
1 0.400000 |<--- This area is the amount of lift
1 0.500000 |
1 0.550000 |
1 0.600000/
1 132.000000\
1 198.000000 |
1 240.000000 |<----This area is the amount of air flow at the above lifts
1 260.000000 |
1 262.000000 |
1 262.000000/
1 1.600000<--- The size of the exhaust valve in inches
1 28.000000<--- The method of vacuum was used for measuring (28"/Hg)
1 0.200000\
1 0.300000 |
1 0.400000 |<--- Amount of lift
1 0.500000 |
1 0.550000 |
1 0.600000/
1 108.000000\
1 156.000000 |
1 178.000000 |<--- Amount of flow at the above lifts
1 190.000000 |
1 192.000000 |
1 194.000000/
Old Dec 27, 2002 | 10:07 PM
DTL504's Avatar
Thanks A lot. trying to brainstorm my 400 sbc.
Old Dec 28, 2002 | 10:10 PM
flyway190's Avatar
Just find and open the .flw file from the menu. It helps to put all of your .flw files in the same folder within the Dyno2000 folder.
Old Dec 29, 2002 | 08:50 AM
DTL504's Avatar
Thanks A lot I have figure it works.
Once again thanks you
Dave
Breazlan
May 25, 2005 12:35 AM
firebird89355
Nov 15, 2004 03:52 AM
jeepguy553
17
May 6, 2004 12:33 AM
onebinky
Mar 24, 2004 11:14 PM
84zeddd
Oct 25, 2003 02:51 PM
