Fuel line question with LT1 swap
Old Dec 28, 2002 | 11:26 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
What side do the fuel return and supply lines run on a tpi car. I bought all new TPI lines to replace my original carb setup because the lines were looking a little shabby. They look very different from my originals and any help would be appreciated. A pic of where they come in at the engine compartment would help also. Thanks in advance.
Old Dec 28, 2002 | 11:31 AM
Electromaro's Avatar
hey man. do you know how many gallons your tank is that you are using for the swap? 14 or 15?
Old Dec 28, 2002 | 11:43 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I think it is 15 but I'm not totally sure. Why? Would that make some kind of difference?
Old Dec 28, 2002 | 11:45 AM
i guess my post wasn't in response to your question. i am trying to figure out which tank i need for my car. i am doing a lt1 swap from an 87 lg4 z28 and i wasn't sure wether to get the 14 or 15 gallon tank. are the demensions the same?
Old Dec 28, 2002 | 12:43 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I don't know about that one. I plan on crossing that bridge in a few days when I can get the rear suspension down and the tank out. My main problem now is that I can't figure out how the new lines go in. They don't match the frame anywhere as far as I can tell.
Old Dec 28, 2002 | 03:25 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
If you got the tpi hardlines from a FI car, they should just follow the frame rail the same from the rear all the way up to about the front of the trans, and then go straight where your carb ones go up and over to the pass side, the fi ones go to just past where the strut mount is against the frame rail.
Old Dec 28, 2002 | 05:28 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I bought new replacement lines for a fuel injected car to replace my carb lines. So to understand this right...the lines go from the drivers side of the fuel tank all the way to the front and then cross over the trans tunnel and up along the passenger side fram rail? I misunderstood when I ordered them and thought the injected lines are all on the passenger side even back at the tank. Thanks again for any help.
Old Dec 28, 2002 | 09:59 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Basically the tpi and tbi / V6 cars use the hardline running from the filter on the drivers side and go alll the way along the framerail staying on the drivers side stopping just short of the power steering box, the carb cars it starts the same but crosses over following the trans tunnel just behind the motor and goes to the pass side cause thats where the mech pump is at, i guess you'd have to go get some custom lines if you want to keep your stock hardline.
Old Dec 29, 2002 | 09:00 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Thanks guys...I finally got 'em in. They look good and so far so good....turns out my problems were caused by me when I accidentally bent the fuel lines when i was putting them up into the car and got caught on something. That slight bend caused me to think I somehow got the wrong lines. Next week the rear suspension and fuel tank come out...I here thats going to be another PITA.
Old Jan 3, 2003 | 03:22 PM
84CamroHO's Avatar
oh yes it is and i taking out the tank right now and it is a b*tch and a half
Old Jan 3, 2003 | 05:51 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I was hoping to be there by now, but work has been a little---scratch that---a lot hectic right now. I am going to cross that bridge on Monday or Tuesday. Just hope my tank is in good shape. I don't want to buy one of those if I don't have too.
Old Jan 5, 2003 | 04:00 PM
84CamroHO's Avatar
what did you use for like to connect the tank to the hardlines and the hardlines to the engine?
Old Jan 5, 2003 | 05:40 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Sorry...I'm not there yet. Unfortunately, all I have done-fuel wise- is drop in the new lines. I haven't pulled the gas tank yet or put in a fuel pump. I also don't have the engine in yet so there are no connections in the engine compartment. Hopefully I'll have the rear end apart this next weekend if time permits.
Old Jan 5, 2003 | 08:20 PM
HybridZ28's Avatar
I used the lines from www.lt1intake.com , they connect to the stock TPI hard lines and have the correct GM quick connect style fittings for the LT1 fuel rail.
Old Jan 5, 2003 | 10:05 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Hey...Hybridz28...those are perfect...thanks for the info.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
