400 starter problem
Old Jan 4, 2003 | 05:00 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
400 starter problem
i need help. today i was working on my 408 and i found that the starter from my 305 doesn't clear the new flywheel. the flywheel is a 168 tooth McLeod flywheel. if the flywheel is off of the motor, then the starter will bolt up to the block. now that the flywheel is on, it won't fit. my question is, is there another starter that i can get that will fit, or can i get the nose of the starter i have now replaced with a smaller one? any suggestions would be great. thanks
Old Jan 4, 2003 | 08:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you have a 168-tooth flywheel, then any starter for a Turbo 350 or 400 Chevy will work.
Go to a parts store and get a starter part # 3510-S.
Only problem is, the flywheel you have, and that starter, won't fit in the F-body bell housing.
Old Jan 5, 2003 | 12:24 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
What exactly is an F-body bell housing?
Old Jan 5, 2003 | 02:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Bell housing out of a F-body car (Camaro or Firebird)
Old Jan 5, 2003 | 03:17 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
I was unaware there was a difference in bellhousings between body styles. I put a 700R4 out of a suburban in my '89 camaro.
Old Jan 5, 2003 | 04:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A 700 doesn't have a discrete bell housing.
The issue isn't bolting to the motor.
Trust me, it's different from any other. Real different. The trans mounting patern is rotated about 20° clockwise as viewed from the front of the car.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
