is this a good combo?
Old Jan 7, 2003 | 12:32 AM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
im looking for 375-400 hp, i wanna go with a stock block form blue chip motors with a SLP cam 224/230duration@ .050" lift. pro top line aluminum heads 200cc intake runner,64cc comb chamber.and a set of long tube runners. is this a good combo? will i need a higher stall? will i need gears? i have 3:27 right now. any help would be apperciated. my car is a 1989 gta with alot of bolt ons.
Old Jan 7, 2003 | 01:26 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: is this a good combo?
Who is Blue Chip Motors? What are "pro top line" heads? What is a "long tube runners"? What bolt-ons that you have now do you plan to reuse? More detail and description would help. I'm probably not the only person who is lost with your descripion... but maybe I am!
Old Jan 7, 2003 | 07:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Blue Chip Motors is a machine shop. Pro Topline is a cyl head mfr www.protopline.com LTRs are... well, LTRs; the stock TPI setup.
You won't make anywhere near that much HP with that on top of that motor. That cam will slow you down from stock is you keep those restrictive stock runners and even more restrictive stock base on there. Put something else on top of those heads that actually allows some flow, then you can use that cam, and then you can easily make 400 HP. I'd suggest a MiniRam or Stealth Ram.
With a stock TPI I'd be extremely surprised to see the engine break 350 HP; very, very few ever do, and then only when carefully massaged and tuned by someone with alot of patience and experience. 320-325 HP is more normal, pretty close to the TPI's "brick wall" of flow limitation.
I'm assuming that you're going to put headers on it, preferably 1¾" with 3" Y-pipe and cat-back.
A higher stall converter would definitely help.
Old Jan 7, 2003 | 07:50 AM
ctandc's Avatar
I don't know......I've seen more than a few guys running 12's with the LTR setup...with the RIGHT bolt ons.
One combo that comes to mind ran high 12's with NO chip tuning. So more power was there for the taking.
If it were me, I'd go with the heads, but unless you plan on upgrading to a 383 later, the 200cc intake runners are a bit on the large side, especially for a LTR setup.
They do make a set with 170-180cc intake runners, look at their site.
The cam IS on the large side for a LTR setup. If you plan on keeping the LTR setup, just use the ZZ4 cam and maybe later some 1.6 rockers.
Port the stock intake base, or score a used Edelbrock or TPIS piece...I see these on Ebay as well.
Then upgrade to a set of Arizona Speed and Marine runners.
Port the plenum, and gasket match to the runner / gasket.
With a good exhaust / headers, and some traction, I would think this combo would be good for easy high 12's, if not more.
There's a local guy here with a 385 stroker that has worked Vortec heads, A cam REALLY close in specs to the ZZ4, 1.6 rockers, the Vortec TPI base, which was matched to the AS&M runners. With headers and a good catback, with 3.42 gears he was runnning 12.80's and was still tuning when the tranny puked.
HTH
Old Jan 10, 2003 | 02:43 PM
1987gt's Avatar
Car: 1989 GTA
thanks for all the help guys. I allready ported the plenum and i was saying i was gonna go with aftermarket runners maybe SLP. i have a flowmaster exhaust allready,I also have many other mods.i here alot of things about the intake i want to use you know after market runners and ported plenum do you guys really think its a bad setup im trying to save money i dont have enough to get the engine done and a after market intake not yet anyway.I would be happy if i could get low 13s for now.do you think i can get low 13s? why do you think 200cc is to much for the heads? i am looking for a high comp ratio like 10:5:1 or so is that good? tell me what you think guys again thanks.
Old Jan 11, 2003 | 03:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Why not go with an aluminum intake manifold and a good 4 barrel, like a 750cfm? If you want to make a ton of power, a carb would be my reccomendation, especially over a TPI setup.
Old Jan 12, 2003 | 03:15 PM
1987gt's Avatar
Car: 1989 GTA
Re: Re: is this a good combo?
in thanks.
thanks for the info but i jut dont like carb set ups i love the way fuel injection runs i think its better all around i am staying with the injection its just a matter of what to change i=on it but i do appreciate your help.
customblackbird
Aug 15, 2021 10:16 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
