Cleaning 25 year old engine?
Old Jan 8, 2003 | 12:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hey guys...
I got my 350 into the car about 3 months ago, but during the swap, i had no time to do any detailing and cleaning beyond what i knew had to be done. Since then, i have tried litterally everything i could think of to clean all the caked on dirt, burned on oil, etc. I've tried engine degreaser (Gunk i think), soap, even just plain water both on a rag and a pressure washer. The worst stuff in on my valve covers. I have used a 2.5" wide paint scraper on them and even that will not take it off!!
Nothing is helping. What do you guys suggest? I'm totally lost now.
Old Jan 8, 2003 | 01:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Simple Green full strength, or that Castrol cleaner - forget the name, but you wear rubber gloves while using the stuff.
Old Jan 8, 2003 | 03:25 PM
Air_Adam's Avatar
Hehe, sounds like strone stuff.. ill give it a shot, thanks
Old Jan 8, 2003 | 04:53 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
theres this stuff that dupont makes. its called 3812s fast drying enamel reducer. i used that on my engine bay to get the caked on dirt off.
Old Jan 8, 2003 | 07:01 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
BRILLIO PAD and ELBOW GREASE...
WORKS WHEN ALL OTHERS FAIL...
Old Jan 8, 2003 | 10:11 PM
five7kid's Avatar
"Castrol Super Clean".
Duhhh...
I used it diluted to clean some pistons I was reusing.
Old Jan 8, 2003 | 10:51 PM
TheViking's Avatar
The best way I've found to really restore old parts is to remove them, have them bead blasted and then repaint to match the original colors. I have found products from SEM and Eastwood to give excellent results. It sounds like a lot of work but the results are well worth it.
Old Jan 11, 2003 | 09:31 PM
Air_Adam's Avatar
I would love to do that, and would if i could, but the main stuff i'm trying to clean is stuff i cannot take off with the engine in the car, like the valve covers, heads, block and intake manifold.. so i have to do it with everything on the car.
Oh well, thanks alot for the suggestions guys
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
Street Lethal
Aug 14, 2015 08:25 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
