how to match 305 '79 with v6 t-5
Guest
Posts: n/a
I wonder what's needed to match '79 305 engine with V6 t-5 manual tranny.
I need for sure 14 spline clutch disc and V8 bellhousing but I wonder what flywheel?
I heard about 153/168 teeth, something about pre 86 with two piece crank seal. What's a matter?
Please don't say "change motor or get another transmission" because I live in Central Europe and it's easier to get the heavy parts togeter if it's possible.
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
you'll need a 153 tooth 2 piece rear main seal flywheel
go to www.McLeod.com and order a 10 inch 14 spline clutch disc
Fastcamaro87
Nov 13, 2001 11:46 AM
