Feul Tank Acess Panel
Old Jan 19, 2003 | 06:56 PM
zz28's Avatar
If you have done this mod w/any sucess please post location and size of hole cut over tank
Old Jan 19, 2003 | 07:13 PM
zz28's Avatar
I dont understand why this is a subject that cant be replied too
Old Jan 20, 2003 | 07:36 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I was thinking about doing it. I drilled a 1/2 starter hole but notice the fuel line are too close. I would have to drop the tank so I'll have 2 inches of clearence or the blade. I could bolt or pop-rivit the panel back on. awhile back someone did do it, he changed his fuel pump in minutes not hours. Alot of people don't like, but cutting a 12"x12" square won't weaking the body that much. It was thick metal, even for a sawzall.
Old Jan 21, 2003 | 04:54 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
On this board it is considered a HACK job, none of the Pro's here will help you cut up your car...but it is YOUR car do what ya want...if you do a search someone posted some pics awhile back.
Old Jan 21, 2003 | 07:29 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
Replacing the pump isn't so hard a job that I'd cut my car. Of course you didn't ask either.
Anyway since I started...
I've done it twice (thank you Autozone). Once two weeks after an appendectomy... that wasn't any fun but I still wasn't going to cut my car... just doesn't seem right...
Old Jan 21, 2003 | 08:46 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
its a total hack job since the lines connect over by the frame rail, you have to cut the lines unless you make a really big assed hole.
i dont recomend it, but if you must, this might help ya
http://www.taekwondoplus.org/z28/fuelpump.html
Bohemian
Aug 15, 2017 05:11 PM
kx3g
Sep 28, 2015 08:14 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
CAMAROBEAV
European Region
Sep 12, 2015 10:04 AM
katrav8
Sep 11, 2015 09:00 AM
