Porting LT1 heads & intake
Old Jan 20, 2003 | 03:49 PM
mat89RS's Avatar
How much gain could I possibly get after fully porting, intake, trottle body, heads ? and maybe bigger injectors ???
Old Jan 21, 2003 | 01:12 AM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
I see some guys on camaroz28.com with all the bolt-ons, home ported LT1 heads and usually the cc306 cam making around 400 rwhp.
Old Jan 21, 2003 | 03:58 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Without knowing more specifics I would guess around 35 to 50 additional horsepower.
Old Jan 21, 2003 | 04:30 PM
mat89RS's Avatar
I'm think it might be better to just save my money and to put it towards a supercharger...
I'm getting tired to work on that old car.
Old Jan 21, 2003 | 05:16 PM
Makaveli's Avatar
search the LT1 tech boards at Cz28.com, some of those n/a cars are pretty quick.. see a lot of guys in the 12s with bolt ons, more with bolt ons and a cam, and arent 4th gen cars heavier than 3rd gens? also a higher stall converter with those 342s eventually will give you some nice results too..
Old Jan 21, 2003 | 07:12 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Ported heads are a great idea. I found a guy who does great work cheap. He will port heads for 400 plus machine work.
My car with these heads and a hot cam should put down 370 whp with an a4
Kory
Old Jan 21, 2003 | 07:26 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
400 hp should be no problem. Heck with my home p&p heads a xe 230-236 plus some other mods including a stall and 3.73 I should be capable of low 12's. I will let you all know if I reach my goal in the spring.
IMO you will not see much gain by the throttle body or intake, but the heads is where the better hp numbers will come from.
Old Jan 22, 2003 | 09:20 AM
mat89RS's Avatar
What is the stall on a 93 4L60 ???
Old Jan 22, 2003 | 12:20 PM
Makaveli's Avatar
check out this post on cz28.com
http://web.camaross.com/forums/showt...&threadid=2214
can be useful if you need any of it, i know i have the stall speed numbers floatin around here somewhere, let me see if i can dig em up lol
Old Jul 13, 2004 | 09:44 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
93 was 4L60E if I am not mistaking
Old Jul 13, 2004 | 09:53 AM
Drakar's Avatar
93 was last year for non computer controlled 700R4 which GM renamed to 4L60 and later when electronics came in to 4L60E
The 93 TB is looked for because it has the proper cable hookups for use with a 700R4.
Old Jul 13, 2004 | 01:11 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
be careful not to throw around "400 rwhp" so casually..
my setup should be there now, but I need better headers ( I don't like our longtube choices so I am getting SLP) but the shorty route may stop me short..
Intake wise I am pretty good, but upgrading from a 52mm tb to a 58 is worth a few ponies, so is porting the intake (which is done already).. etc..
I am just saying that it was relatively easy to get a solid driveable and repeatable 373 hp and 360 tq.. to get those last 27 rwhp will take an extra 1000+ dollars.. on top of the cam 400, Lloyd Elliot headwork 1000, rockers 350, lifters 200, injectors 220, pushrods 110, and dynotune 400...
and now a better clutch and the billet flywheel icing on top, 700...
Fast is not cheap, it is fun but not cheap.. the next LTx is going forced induction to keep up with the LSx crowd..
Old Jul 23, 2004 | 02:51 PM
LT1guy's Avatar
Car: 1987 Trans Am
Ported heads and a cam, even with all the bolt ons, isn't a guaranteed 400rwhp by any means, esp if they're ported by an amateur. 360-370 is fairly easy to get, but more than that requires a more radical setup than average.
Old Jul 23, 2004 | 05:35 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
There's a guy on CamaroZ28.com, Lloyd Elliot, from what I hear he does some bad *** porting! His sn's Nightrain66 I think, he's in TX. He's got 3 packages, that he custom grinds cams for, and I've heard of up to 400HP with just the porting and custom grind cam.
Old Jul 23, 2004 | 06:10 PM
Car: 88 Iroc
Transmission: t 56
I believe J's ta has Lloyds package. I have a set of his heads with my hot cam. They seem to work very well. I am trapping at 112mph. I hope to surpass the 4oowhp mark later this year with a cam swap and a few other chaanges.
Lloyd is a great guy I would do business with him anytime.
Kory
midge54
Jan 29, 2017 07:00 PM
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MoJoe
Sep 24, 2015 09:12 PM
