engine swap question
Old Jan 22, 2003 | 05:17 PM
appollo's Avatar
I've got an 89 GTA 5.7 that i toasted the motor in, cracked heads cracked block. She overheated badly. I also have a fresh older 350 4 bolt main from around the 70's that I'd like to install.
So far all I can tell is that i have to machine the TPI intake to allow for mounting on the older block.
I have a crane energizer cam in the older block, is this compatible with the TPI system, I was told that I need to swap the cams from the original motor for the newer computerized cam?
I was also told to purchase retrofitted lifters at $660.00, is this necessary?
Your words of wisdom would be greatly appreciated.
Is there anything else I've missed, aside from generally swapping everything from one block to the other, distributor, pulleys, etc.
Old Jan 23, 2003 | 07:33 AM
85TPI400's Avatar
You will have to slot the center holes on the intake, Which Crane Energizer part# do you have? The retro fit lifters are not necessary, you could just use a Flat tappet cam and lifters but it would have to be computer friendly. You need 7 bolt heads (if you are using stock exhaust manifolds) if not headers will work with the 6 bolt heads. Besides that everything should bolt right up.
Tony
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
