new engine
Old Jan 25, 2003 | 05:58 PM
1991BlackBird's Avatar
new engine
Hey how much would it cost to get a new engine put in my va profesionaly if i had the engine? im just looking for a guesstimate cause ive heard everything from like 1000 to 7000 thx
Old Jan 26, 2003 | 05:50 AM
ede's Avatar
ede
you should call shops in your area since rates vary alot. i'd guess 15 to 20 hours flat rate, but i don't have a flat rate book here.
Old Jan 26, 2003 | 01:15 PM
MdFormula350's Avatar
i guess it depends on what engine you had? and what engine their putting in...
Old Jan 26, 2003 | 01:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
OK...
How much would it cost to build a new house? I hear everything from $40,000 to $10,000,000.
It all depends on what you want. If all you want is the cheeeeepest possible slap something in there that will push the car around, and whatever you put in excatly matches what you're taking out, and no parts have to be swapped over except maybe the air cleaner, then $1000 might do it. I would expect something more like $1500 to $2000 for a typical replacement engine install, where lots of parts have to be moved over like the intake and valve covers and oil pan, and lots of the old parts can't (or shouldn't) be re-used, like radiator hoses, belts, fluids, etc. That stuff adds up.
Figure a shop rate of $60/hr or so, plus about $400 worth of stuff that has to be replaced, and anywhere from 15 to 30 hours of shop time.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
