350
Old Jan 28, 2003 | 11:08 AM
91zconvt's Avatar
Car: 87 Iroc
Hey, I have a '91 Z Convt. with a 5 speed. I'm wondering, It has TPI, so what would have to be changed to swap with a 350? Would it just be remove the old engine, and bolt the new one in? How much (ballpark estimate) would it cost to bring it to a shop and have them put a 350 in it (cost of engine and labor)?
Oh, and what else would have to be done to make this combination work? I'm assuming the tranny would have to go, and I'd need some SFC's, but is there anything else?
Old Jan 28, 2003 | 12:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you get a 350 of the same vintage as your 305, with the correct year range heads, then the only things you have to change are the injectors and the chip, and possibly add a AFPR.
The trans will bolt right up.
SFCs are always a good idea in these cars, even if all you have under the hood is a 4-cyl.
Old Feb 4, 2003 | 12:15 AM
Russ-So Cal's Avatar
You will also need to get the 350 knock sensor.
Old Feb 4, 2003 | 02:50 PM
MdFormula350's Avatar
i am praying that the 5 speed holds
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
