engine and ecm matching
Old Feb 3, 2003 | 07:35 PM
jc33's Avatar
Car: 1992 Camaro RS
Transmission: T5- manual five speed
im swapping my v6 for a v8 350 tpi. the engine im looking at is an 88 350 tpi out of a gta. my car is a 92 v6. i know 92 350s and 92 v6's use the same ecm. so i was thinking about trying to use my ecm with the 88 engine. im pretty sure the egr and air systems are the same. im not sure about fuel injectors matching though because the 88 had a cold start valve and the 92 doesnt. does anyone have anymore info on this, do you think it will work? any opinions? help is greatly appreciated. I also know the Map sensor is the same.
Old Feb 3, 2003 | 11:31 PM
Russ-So Cal's Avatar
I don't think it will work unless you change the tpi. The 92 tpi was speed density, 88 is maf. Are you sure that the v6 is the same computer as the v8 tpi cars? My 89 was different for the v6 than for the v8.
Old Feb 4, 2003 | 01:11 AM
jc33's Avatar
Car: 1992 Camaro RS
yeah the v6 and v8's are the same ecm from 90-92 i looked up the part #'s. just different proms. to switch to speed density dont you just unplug the maf sensor. ive heard its pretty easy to switch over. damn computers.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
