What kinda stuff have you done with your motor out?
Old Feb 13, 2003 | 09:59 AM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
I will hopfully be getting a 305 for free soon and I would like to rebuild it and put it into my S/E.
Here's the deal. What kind of stuff have you all done with your engine bays while your motor was out?
I would like to repaint the S/E to black and the engine bay is currently the original "poopy" brown color. I too would like to paint it black.
Should I go with a flat, semi gloss, or gloss black? What other ideas can I do if and when my motor comes out?
Thanks guys,
bill
Old Feb 13, 2003 | 12:18 PM
timtpi305's Avatar
if the car will be show put a gloss color in the engine compartment if you just want it to look decent you can put a flat color. make sure its high temp paint.
Old Feb 13, 2003 | 12:21 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
if its for show, make the engine bay the same as the body color.
Old Feb 13, 2003 | 11:39 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i found that if you're not going to clean it everyday then using some grey primer first and a little sanding, then going to semi-gloss black does wonders for it. It looks shiney but not too shiney where it looks weird.
I say semi-gloss all the way.
Steve
Old Feb 14, 2003 | 07:52 AM
vwdave's Avatar
As for me.....
Change the cam to a LT4 cam.
Paint the inside of the engine bay flat black.
Put a sheet of dynamat on the firewall. (I am a wuss when it comes to engine and road noise.)
Old Feb 14, 2003 | 09:10 AM
Originally posted by vwdave
As for me.....
Do mean to put a LT4 cam in the 305? I heard that changing the heads, putting a cam, and headers on the car will liven it up a bit. Oh and a new intake.
thanks for the tips so far....im leaning toward semi-gloss paint....
Old Feb 14, 2003 | 09:24 AM
vwdave's Avatar
No, 350 crate motor.
BRoss99
Aug 10, 2025 05:08 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
