any special 'tricks' to spling the tranny into the motor when dropping the motor in?
Old Feb 13, 2003 | 10:45 AM
Nasty_Bird_'90's Avatar
My l98 is going in the car tomorrow (finally!) and I'm just looking to see if anyone has any tricks to splining the tranny into the motor as you're dropping it in. It seems to me that getting it to line up nicely is going to be a PITA. Any help is appreciated. Thx.
Old Feb 13, 2003 | 10:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Piece of cake. Don't worry about it. That's one of the esaiest parts of the whole procedure.
Loosen its mount bolt, slide it as far forward as it will go, and raise it up to where it's against the tunnel. They'll hook right up.
Old Feb 13, 2003 | 12:14 PM
timtpi305's Avatar
disconnect the driveshaft put the tranny in neutral drop the motor in and spin the shaft until it lines up. happy swapping
Old Feb 13, 2003 | 08:38 PM
Ok! Seems like I've been worried about nothing. I'm used to the LS1's where you bolt the tranny to the motor while it's on the stand and lower the car onto it. Thanx guys
Old Feb 14, 2003 | 01:47 PM
Pontiacman's Avatar
If You have an Automatic make usre the Torque stays with the transmission. Make sure it is locked into the pump. Lower the engine, and bolt it up, then bolt the torque. If you don't do it this way, you're pump won't be engaged even though everything is attacked properly. Then you will blw the transmission.
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
crazynights
Aug 21, 2015 06:53 AM
mizz0313
Aug 12, 2015 06:45 AM
