Motor Swap
Old Feb 16, 2003 | 09:23 AM
Tang's Avatar
Motor Swap
I have a 91 Camaro RS it had a 305 TBI eng. E, I replaced it with a crate motor GM #12512151 Eng. 7 I also changed the injectors to 21lb. Everything hooked up okay runs good I still have orginal computer and prom for a 305. Idle is a little lower then before, I'm guessing the prom differance between a 305 and a 350.
Any suggestions on new proms. or leave it be. I would like to make sure I'm getting all my horses out of this new 350.
Old Feb 16, 2003 | 04:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
what kind of induction system are you using, tpi? The usual tbi injectors come in 45, 55, and 65 pph flavors. As always, its a good idea to get into prom burning after an engine swap. Youll never get the full 100% out of the engine if you dont. The stock prom is crap. I still have mine and i can tell you that first hand. Tell us some more about your combo and then we can make some more recomendations.
Old Feb 16, 2003 | 07:30 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Like he said, we would need some more information on your setup before giving you the best advice.
Old Feb 17, 2003 | 07:51 AM
Tang's Avatar
motor swap
I'm still using the stock set up for air induction, the only change is a K&N filter in the stock air cleaner, stock TBI with GM 17112412
Injectors. These injectors are for a 1991 police car 5.7L TBI. They are mated to this replacement engine. according to GM.
Old Feb 17, 2003 | 10:59 AM
Car: 88 Camaro SC
Engine: SFI'd 350
im not too familliar with what part # coorespond to what engine but i assume your using the lo5 with the 65 pph injectors. If thats the case, you can just use the 350 knock sensor, knock module, and, if your car is an 89+, you can use the prom for a 9C1 cop car. That should be good for starters.
Old Feb 18, 2003 | 07:01 PM
Tang's Avatar
Has anyone had any luck trying one of those spacer plates that fit under the throttle body, for extra atomization which increases power. They work on the trucks because of the extra hood clearance, but I have'nt heard of one fitting under a stock Camaro hood.
Old Feb 18, 2003 | 08:57 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I think you can fit about a 1/2" spacer under the throttle body and still clear the hood, but I'm not sure on that. I've read several posts in the past though that state the spacer was a waste of money. From what I've heard you don't need or want a spacer.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
