Cam Swap - AC Fluid
Car: Camaro IROC-Z Convertible & Camaro
Transmission: Auto & 6 SPEED
Axle/Gears: 2.73 & 3.42
Cam Swap - AC Fluid
Hey everyone,
this may be a dumb question, but is there a way I can do a cam in an LB9 swap without draining the A/C fluid ? if so how ? what all would I have to remove to make this work ?
Car: 4
Engine: 6
Transmission: 5
Yes.
Simply move the A/C compressor and condenser coil together as a unit; set them off to the side, out of the way, within the reach of the lines to the evaporator.
