Carb, SD, or MAf for 400?
Old Feb 18, 2003 | 09:44 AM
mastrdrver's Avatar
Just wondering what you guys with 400 sbc have done for your setup, and any bad experiences.
Thanks,
Jeremy
Old Feb 20, 2003 | 09:24 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
My SBC 408
Engine: 400 SBC ID# 330817/14y139664/ T0508CSU
(4.125 bore X 3.750 stroke) after .040 bore (4.165 bore x 3.75 stroke =408)
Crank: Scat 9000 Crank 3.750 6.00, Internally Balance
Piston: Wiseco Pistons Part# PT020H4, .040 over, 5.4cc; 430 grams
Rods: Eagle ESP 4340 H-Rods 6.0
Block: Zero Deck: 0.000
Compression Ratio: Static-10:48 Dynamic-8:30
Cam: Grind: Ultradyne: 280/288 Lift.525IN/.540EX Dur: 247IN/255EX
LSA: 110 ILC: 106
Heads: AFR 195 part# 1035 w/23º valve angle, 74cc, drilled steam holes
Head Gasket: Fel-Pro-1014 / 0.039
Intake: Edelbrock RPM #7101
Carb: Holley Street Avenger 770 or 750 (3310)
Rear End Gear: 3:73
Transmission: Pro-Built Street/Strip 700R4
Stall Converter: A.C.T. 3000 Stall
Exhaust: Hooker Super Comp headers 1 5/8 Headers part # 2460-1 ceramic coated;
Hooker Super Competition high flow cat-back exhaust system, Intermediate pipe: 3 in.
* Tail pipe diameter: 2 1/2 in.
* Dual tail pipes out the rear under the bumper
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 9, 2015 10:01 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
