Famous LT1 Swap
Old Feb 22, 2003 | 03:10 PM
AFast83z28's Avatar
Famous LT1 Swap
I have tore apart my 83 full on the iterior minus the dash/steering column. I have bought a painless wiring harness for the 94-95 LT1s. Anybody know how hard the painless harness is to put in? Also can I use a stock TPI fuel pump? I am hoping this won't be super hard. Also I am using some gauges out a 1994 camaro so that they fit right in. I will have to fabricate motor mounts. I am not worried about A/C right now. Anything else I should owrry bout? I am going to use a Permacool Aluminum Radiator so no wories there. Should I buy the painless harness for some electric fans that turn on/shut off at a certain temperature? Any info you can help with would be great. Also I have read all the LONG posts about LT1 swaps.
Old Feb 23, 2003 | 01:43 AM
HybridZ28's Avatar
Re: Famous LT1 Swap
Can't help you with the painless harness since i used a stock 94-95 F-body harness.
Yes you can use the stock TPI fuel pump.
If your car currently has a v8 then use the current motor mount brackets on the LT1. If not find a set of a core motor in a salvage yard.
Your '90 RS speedo should be 4K pulse and will work with the LT1 vss.
I would grab a 4th gen f-body radiator, fans and all the hoses from a salvage yard. Dirrect bolt in.
Hard to see in this pic, but thats what I used, just trimed the radiator top mount panel from the 4th gen.
Old Feb 23, 2003 | 07:51 AM
AFast83z28's Avatar
Speedo?
I wasn't using the 90 gauge cluster? would one out of a 1990 work? also i am using a th350 not a 4l60e. so i can use my stock motor mounts? would poly motor mounts work?
Old Feb 23, 2003 | 09:11 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I also bought the Painless Harness and with some luck, will be starting on it an a few weeks. I'll let you know how it goes.
Old Feb 23, 2003 | 09:46 AM
AFast83z28's Avatar
Painless Harness
I will be starting on mine in a few days. I am keeping a daily journal of EVERYTHING I do. I started when I started pulling outt he interior and the sizes of all tools and all that stuff. I am trying to keep a journal of problems and tips for people that do it in the future
Old Feb 23, 2003 | 04:24 PM
Momar's Avatar
What all does the painless harness include. It is probably just everything that connects to make the motor run but not gauges and such right? I have a 94 impala ss LT1 and the stock harness. What would have to be done to make the gauges work in either of these?
Ben
Old Feb 23, 2003 | 04:28 PM
AFast83z28's Avatar
Here's what I am doing
1) Bought a painless harness
2) Buying a 94-96 gauge cluster (direct plug in i hope)
3) I am hoping the light harness comes all the way to the bulbs. if it not a direct connection, i will buy the wiring harness from the bulbs back from a junk car.
4) I am using a TH350 so I am not using the tranny harness (muine didn't come with one. bought it that way).
That's all I can tell you now. I will notify this board with any problems.
ALSO YOU WILL HAVE TO GET A DIFFERENT DRIVE/DRIVEN GEAR PROBABLY!
Old Feb 23, 2003 | 04:33 PM
Momar's Avatar
I am using the 700R4 so I already have the right tranny gears. I am not sure, but from what I understand the painless harness doesnt go to the gauges. I think it is just what is needed to make the car run. I think that you would need the stock harnees to wire up the guages. I know most people I have read about doing gauges had to splice wires at the bulk head connector for the gauges to work properly. Here is a site that I found a link to on camaroz28.com that looks like it could be very useful. http://csce.uark.edu/~jgbertr/rb/4th_gen_tech1.html
Ben
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
