305 distributor to new 350 ?'s
Old Feb 28, 2003 | 04:45 AM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
Will my 85 tpi distributor work on my 88 l98 block. Is the only thing I need to get is a bronze gear to run with my zz4 cam?
Also
How do I delete the cold start injector?
These are my last few problems and the motor will be in.
thanks,
Rick
Old Feb 28, 2003 | 03:26 PM
Guest
Guest
Posts: n/a
You'd be better off getting a GM gear (or similar... not brass, but 'melonized'... whatever that is ) instead of brass... brass wears out. I wont say to order an 88 gear from GM though, they were nice enough to change the shaft size on the newer distributors. Other than that, it'll drop right in.
Old Feb 28, 2003 | 03:49 PM
jeffsbluez's Avatar
Car: 91 z28
You could also just buy a new one for about $150.00 . That one from 85' probably has seen better days. Just my.02
Old Feb 28, 2003 | 08:47 PM
rdog30's Avatar
Car: 85&95 Trans am
I think I will just replace it. Except I have the in cap coil instead of the external one. Should I just order one that a vette used? Vettes had in cap coils.
Thanks,
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Derick15
Sep 17, 2016 05:28 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
