Ignition Setting-Up
Old Mar 4, 2003 | 07:25 AM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
Ignition Setting-Up
I'm just about ready to drop the 455 in and hook everything up. It has an HEI distributor (with the coil and module inside the cap),
so I was wondering, what hooks up to the distributor to make it and the coil work?
If you can get any detailed pics of your or someone elses HEI setup, that would help me out alot. I don't know what all I need to hook my ignition up. I don't know what goes where. Please help!
Old Mar 4, 2003 | 07:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Same as last post on the subject....
Switched 12 V (pink wire) to the Batt terminal, and tach wire to the Tach terminal. That's it. Gotta be the simplest thing to wire that's ever been invented.
Old Mar 4, 2003 | 07:43 AM
427camaro's Avatar
Engine: 4.0L DOHC
That's all, then it will crank as long as its got fuel, and the starter is hooked up?
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
