New CHP, big inch small blocks
I was reading the article in the new Chevy Hi-Po about big inch small blocks and I was wondering if anyone on here had built one. I was really intrigued by the article and would love to build one of those engines in the next few years, but I wanted to see if anyone had any experience with them and if they had problems finding parts and such.
*edit: for anyone who hasnt read the article, I'm talking about 440 range and up small blocks. I know in the article it says a number of places for cranks and stuff, but I searched around on the internet today and couldn't find any of the really big stuff thats in the article, like 4.250 stroke cranks for 4.250" pistons, so I'm assuming it would all have to be custom. thoughts/ideas?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You also need a custom block. Nothing like that will work in a production block.
By the time you're done building a big inch small block, I could build a BBC for a lot less money.
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
yea motown used there tall deck block for that motor...
there building a 4.25 bore 4 inch stroke small block...
4.25 bore
4" stroke...=454 cubes of bad@ss small block
also =very pricey
4.25 bore
also =very pricey
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
I read the article that you were refering too in CHP & it does not go much into specifics. I bought a book a few years ago & I believe it was called how to build big inch or long stroked small block chevy's or something like that, "I have it at work & when I go back in a couple of weeks I can get the true title of it for you if you'd like. It was comprised from past engine build up's from Hot Rod or Popular Hotrodding ? Magazine & went into quite a bit of detall on parts used, manufacturers & dyno results. It covered build-up"s of all sizes, pretty much everything 350.377.383.400.406.427 & 454 smallblocks.
BTW, you do not need a 4.250" stroke crank, as f-crazy posted a 4.00" stroke will make a 454 & I don't know if they make a 4.250" smallblock crank or not . It takes some block clearencing for a 4.00" crank to swing. even on an aftermarket block & as Stephen 87 IROC stated a production block isn't a option for that many CI's in a smallblock
Bruce (70GTO)
Bruce (70GTO)
Car: 89 Iroc Z
In the book that I mentioned above, they built a 427 & used a production block by boring it to 4.125" & using a 4" stroke crank, but IMO the cylinder walls get pretty thin & they had to do a ton of grinding for everything to clear, plus a bunch of machine work. If I remember correctly they also had made a 454 using a factry block, however it wasn't just a run of the mill block. It was a particular casting # and they are not very plentyful.
Yeah I checked out World Products and their Little M block would work, not sure about cam clearance on that one though. not too worried about it right now, its still just a crazy idea.
Stephen, yeah I know you could build a big-block cheaper, but as soon as you pop your hood the cats out of the bag, everyone knows what you've got. With a big-inch small block, no ones the wiser, the only thing that might give it away would be the incredibly large for a small block headers. Some poor fool is going to want to race thinking you just have a 350 or maybe a 400, when in fact you're running a 454 or maybe even the 482.
70gto, if you could get that title, I'd appreciate it. I'd like to get as much info as I can now before I even get close to being ready to build such a monster.
I checked out Eagle cranks yesterday in Jegs and they listed a 4.00" stroke crank, but not a 4.25", so thats why I assumed anything larger than the 4" would probably be a custom grind.
Can anyone suggest pistons or a place that has 4.25" ones?
Engine: CARBED LT4
Transmission: MK6
i said a 4 inch stroke and a 4.25 bore
4.25 bore
also =very pricey
4.25 bore
also =very pricey
Car: 87 IROC L98
Even www.jepistons.com who carry a huge assortment of race pistons, don't have anything for that combination of parts.
Engine: CARBED LT4
Transmission: MK6
my bad gto i read it wrong....
yea i doubt there are many companies who make the pistons..but as this catches on im sure there will more compainies makeing them,...but this is a serious motor and expect to pay serious prices
Car: 89 Iroc Z
TexasLT1- I'll be sure to get the tilte of the book to you, however I'm on vacation & won"t be going back to work until the 20th "unless by chance I stop in before then", but never theless I'll get it to you.
As far as a 4.250 crank, I'll be going to my engine builders shop in the next couple of days & I'll see if he's ever heard of a smallblock crank larger than 4".
Bruce
Bruce
Stephen - yeah I assumed that it would probably take some custom parts. but by the time I'm ready to build one I'm sure the parts would be out. and if not, oh well, its a cool thought. besides, if all else fails, parts are already available to build a 443.
70GTO - thanks man, I'm not in any hurry for the title so whenever you get a chance is cool. besides, if I got it now I would only get distracted from all my school crap so its cool.
Another thought, the article states that the engine that World Products built, a 443, used their Motown 220 cc heads. Now, 220 cc heads are the largest I've seen for a small block. And I would think those would be fairly close to being maxed out on a 443, what kind of heads would you have to use if one were to build a 482 SBC?
Car: 87 IROC L98
How much money do you have?
www.brodix.com has SBC heads that can flow over 400 cfm to feed those exotic large SBC engines.
www.canfieldheads.com has a couple but they're not so extreme.
I'll just say that when the time comes I won't be too worried about how much it costs. I would like to keep it reasonable and not spend extreme amounts on it, but its not going to be on a tight budget either. I'm going to the Air Force Academy next year and we get a substantial signing bonus our Junior year when we contract, I plan on investing about half of it and putting the other half towards my car. If I do decide to build this engine then I plan on doing it right and not cutting any corners, if that means spending a little bit more then thats fine.
Thanks for those addresses Stephen, I'll check them out in a little while and see what they've got.
If you plan to use a giant inch small block like that, good for you. I hope you only plan to street race it for maybe a year or so and make as much money as you can and then sell it
With a inch monster like that you need a head that flows over 300cfm and 400cfm would be better
Minimum would be 18* heads but some brodix 15* would be better.
Car: 87 IROC L98
400 cfm heads should produce about 825 hp. I don't have any flow numbers but the heads on my BBC were rated at having 269cc intake runners. They've been ported so they have a bit more now but flow nowhere near 400 cfm.
Car: 1981 Toyota Supra
Engine: 5M-GE 2.8l DOHC I6
Transmission: 4 speed auto w/OD
Definitely seems to me that the heads would become the limiting factor on a big cube small block. BB heads are just huge compared to SB heads, can you really get enough flow out of them? Sorry for my kinda newbieish question, just trying to learn what I can. What about those 16 valve heads (don't remember who makes them), I heard those had off the chart flow numbers. Oh yeah, small blocks with big cubes are cool!
Toyota Guy - nevermind
Stephen - The article says that World Products just used a set of their 220cc Motown Heads, didn't say anything about porting or anything, and that engine produced 607 hp. So basically for a street/strip engine any of the exotic heads would be pure overkill? I didn't even want to look at the prices of SBC heads that flow in the 400 range. But if the Motowns only flow in the 300 range, why would you need something that much larger?
Car: 89 Iroc Z
Book Info.
TexasLT1
OK, I've got the information for you
The book is; "How to build Big Inch Chevy Small Blocks". It is Volume 9 of the "Hot Rod Technical Library" "The Best of Hot Rod Magazine"
The book is published by,
Cartec
11605 Kost Dam Road
North Branch, MN 55056
Phone 651-583-3471/800-551-4754
(Sorry, no mention of a web site)
There is quite a bit of good research & reading in this book. Hope this helps.
If you can't find a copy of it, get with me & I'll send you mine
Thae Care, Bruce (70GTO)
Cartec
11605 Kost Dam Road
Originally posted by TexasLT1
Toyota Guy - the problem with the 16V heads like you are talking about is the rediculous price for not that much greater performance over a regular small block head, especially when you factor in the complexities of switching to OHC. There are plenty of SBC heads that flow just as much or more than the 16V heads.
both need insane compression to run well too
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
There are parts available right now to build a 461 CI small block:
Use a Dart Iron Eagle block
Lunati assembly part #EA68
4.155 bore & 4.25 stroke crank=461 CI
Or use a 4.185 bore and 4.125 crank for 454 CI
http://www.dartheads.com/bliron.htm
http://www.holley.com/HiOctn/ProdLin...SBProRace.html
Part #: EA68
Pro Series crankshaft with all pin holes drilled, 4.125" - 4.250" stroke. Minimum 6.000" Lunati billet connecting rods, Lunati flat top or dome pistons, bearings and rings.
Figure about 2g for the block, 3500 for the rotating assembly, etc
With the stock 400 block, I have a 434 CI-4.155 bore & 4" crank
Good luck
Part #: EA68
Good luck
bbunting, thanks alot for the info. I'll check into it later on and get some definite prices. And try and figure out a fuel system for the beast. I would like to keep it fuel injected but not too sure how well that would work. Like I've said before, right now this is just a crazy idea I'm checking into to see if I could pull it off in a couple of years. How streetable is the 434 you run? Or was it even meant to be streetable? That is my main concern is streetability. While the car would absolutely see track time, I plan on building more for street use. Therefore I would want to build something that wouldn't need to be torn down ever so often and rebuilt.
Thanks,
Tristan
Thanks,
Tristan
Car: 1990 IROC Z
Thanks,
Tristan
Thanks,
Tristan
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Well, I've got a serious jones for a 421 now. I've geen doing some looking, and It seems like you can get shortblocks in the $3K-$4K range and assembled longblocks for $5K-$6K. I want Fuel Injection, too.
I think a '421 SD' Trans Am would be a baddass machine, don't you ?
I've also been toying around a long-rod 389 with a 'Tr-Power' EFI setup breathing through three TPI/LT1 throttle bodies.
Maybe I'm just nuts.
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I beleive Monty is running a Small block 427 pushing nearly 1300 Horsepower and it all fits under a stock hood.
taking a big-small block and cramming it full of intercooled boost is a good way to make tons of power, and still get decent fuel economy it seems.
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
large engines can be built up from converted diesel blocks.
'68-72 blocks had the thickest main webs
source: Hotrod ENGINES winter 2002
And the olds rocket block can work
in those 'large engine' build ups
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
I just saw the video of your brothers car. WOW!
