power estimates
Old Mar 9, 2003 | 11:22 PM
fbody83's Avatar
Car: 1983 firebird S/E
Engine: Built 350
power estimates
What power do you think this could achieve
Iron heads 170cc intake runners, Outflow Camelhump "fuelies"
Speed Pro (Federal-Mogul) Flat Top HP Pistons
Forged 5.7" Rods, Speed Pro (Federal-Mogul) Rings
Crane/Clevite 292 (duration @.050" 230I/230E, Lift: .480"I/.480"E, Lobe Seperation: 109) Hydrallic Flat Tappet High Performance Camshaft
Clevite Lifters
Elgin High Performance Valve Springs
Melling Pushrods
Professional Products Power Plus High Performance 360 Degree Aluminum High Rise Single Plane Intake Manifold
Carter 750 cfm Carb
HEI Distributor (with HP advance curve)
The car will have an automatic trans with true dual exhaust that will have an x-pipe and 2.5 inch piping, no ac, no emissions
If i left an vital info out let me know, otherwise take a guess at it. Thanks.
Old Mar 10, 2003 | 11:38 AM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Maybe you could tell us what the engine size is.
Old Mar 10, 2003 | 03:12 PM
fbody83's Avatar
Engine: Built 350
Old Mar 10, 2003 | 03:25 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
I put it into an engine analyzer program and came up with 355 lb/ft torque and 338 hp. I'd take that with a grain of salt though. That was with standard dyno running conditions as well (60 degrees/no humidity/at sealevel). Basically, this will probably be the most power you'd make. I also didn't know what compression you were running. I used 9:1. Also, the specs I put in weren't exactly what your engine has. Again, grain of salt.
Old Mar 10, 2003 | 04:39 PM
fbody83's Avatar
Engine: Built 350
Thanks man, the compression ratio is 9.5:1 if your wondering and the reason i ask this is because i dont know if they guy is tellin the truth about it. He doesn't have proof of it but he said the engine alone will make 375 to the crank. But i guess i will have to wait and see when i dyno it.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
